i rebuilt a 24 ft partybarge and took my 1987 70 hp johnson on it, controls and all. the motor was originally on a 14 1/2 tri-hull. so i put it on the pontoon with original prop to see how it did and it surpassed my expectations and would really plane out and move across the water. but the other day i backed it into a truck and bent one of the fins. i replaced the prop with the same as it had on it, 13.25 17 pitch and it is running terrible. it won't plane out and is plowing in the water and the back has a weird wake behind it. (sorry for the non tech terms) so i came home and figured i would try to fix the old prop and put it back on to see what it would do. nothing has changed on the boat at all except for the prop. when i started straightening out the fin i had bent i realized that they were all at different angles and in comparing it to the new one, i think only one was in the correct position, the other 2 were much flatter. in looking on this forum it seems that an 11 pitch is what is recommended for my application. so here is my question. is it possible that the boat ran so well before because the 2 fins were flatter and closer to the 11 pitch than the original 17? thanks in advance.
