hello everyone, I'm new to the forums and have a couple questions that hopefully someone can help me out with. I bought a used 1976 85hp mercury outboard and it doesn't have a prop on it. My old caravelle boat currently has a 65hp 3 cylinder mercury outboard on it and I'm at a loss as to what size and pitch prop I will need to get for the 85hp. My boat is a 17' older caravelle that is fiberglass and I'm guessing weighs pretty close to 1000lbs. I won't be using it as a ski boat like in years past but rather fishing and mainly trolling at 2-3 mph. Any suggestions on a prop that will get me some one slow speeds and not over rev the motor? The 65hp worked perfectly speed wise and all but it needs a new distributor ( I dropped it and broke the rotor off). Also I'm curious as to if a midsection off an inline 6 will fit on the 85hp? I don't have power tilt and trim, but have found a really good deal on a lower unit and midsection with the power already on it and a pump with it also. Thanks in advance!
