Do you have to be so snotty? Just because a a procedure is different than yours doesn't mean it is wrong.
Was the setting in the picture your one and only adjustment?
Its a wonder that the boat handles normally when the foil appears to be 2" under water.
When a boater happens to select a prop incorrectly A friendly Explanation of basic prop selection and boat setup
is the way to handle things.If a motor is setup too high the tach and slip will tell.
IROT Is just plain inflammatory. Rule of thumb is again a starting point.It appears that on your example "about even with the bottom"
is too high.
I've been on here 12 years.Your attitude drives people away.
OK, as suggested by forum moderator let's be polite, what bothers me is that after posting lots of proven examples which no one does, which are product of plain practice even personalizing ones for forum menbers. Only 2 boaters have issues with my posts when having lots of happy boaters in UK, USA, Canada, Australia, to name some countries, boaters that have benefited reading my posts and going after them. Doesn't have to do with being snotty, it's that like sharing my boating experience and make boaters happy, that's the purpose & spirit of the forums.
Going back to the posted example :
A boat/engine combo is not a car, van, motorcycle in which you only seat, drive and have fun with. A combo is governed by different tech parameters, an innefective instalation procedure will not take all the ponies out of under powered OB's if in pursuit of achieving so. OP should test t both posters given parameters by himself and determine which one worked for him.
Besides spot on engine height, which other adjustment was there to do, playing with trim settings ? as said it's a manual trim, settting was dialed at a hole that achieved combo riding parallel to water level with well balanced deck. In this particular case, OP is not going to chop transom down, the only way to solve that highly exposed AV plate would be installing a exterior jack plate and play with different engine heights till spot on height is dialed as of the lower leg posted pic. If OB is real heavy (4 strokes) Jack plate could off-set OB weight at back transom.
To state that combo performs wonderfully with 2" under water must do so in all water conditions. OP has not said a word about having tested that combo on choppy windy straight water courses, even at close tight turns at speed, probably being a newby likes the actual behaviour of that combo, if that's ok, to each his own.
Don't have prop issues, you should always test stock props or at least the one that is currently installed when buying second hand combos, then go from there selecting other pitch props to suit your boating applications, at least we fully agree on that point.
Having a long boating life says nothing if someone keeps schooling other boaters with hints, rules that haven't been fully tested and evaluated during plain water practice by "themselves".
Did the Wright brothers flew by plain theory ? definitely not, give other posters plain practice a water evaluation, you'll be highly surprised on what can be achieved with under powered OB' as opposed to boating theory.
Happy Boating
