Hey everyone I have tried to do some research on hooking up dual gas tanks online and really haven't found my situation. I bought a 24' 90' suncruiser toon that needed to be re-done. It has a little 40hp and came with a 6 gal portable tank that fits inside the corner of the sundeck compartment. I have been using a portable 2 1/2 gal tank to use a a reserve when out on the water. I am always going to Torch Lake, MI which is a good size lake and has a few lakes that connect. That being said I would like to be able to do some river cruising without worrying about if I will have enough fuel to make it. I was given one of those gas caddys that is a 14 gallon tank on wheels "flow n go" type. It did not come with hose and pump and instead of buying one I would like to just hook it up to the motor so I had dual tanks. Since it stands up I would not be able to fit it in the same compartment of the 6 gallon so it would be on the other side of the boat. I would use the 14 gallon as my main and use the 6 as a reserve. I have seen many post about a "Y" or "T" valve, some even using a 12 volt with a toggle switch at the helm. I am looking for some ideas on how to hook this up or what has worked for others. Might be a dumb question but can I even use the caddy as the main tank? I have attached some photos. The 6 gal tank sits in the back port side corner. I decided I would like the open storage on the starboard side so I left the sundeck off. I would place the the caddy on that side (starboard). I appreciate the help and ideas!
