Hello everyone, pretty new to owning a pontoon boat. I picked this 2008 Sun Tracker 21 with a 50HP Merc on the back and for the life of me cannot get this thing to cruise at a decent speed. Done a ton of googling and it's like the motor "spins out" and it looses all traction, I have to back off the throttle, then I can go again for a bit. I think this is cavitation?
I have always been thinking the motor is low enough, but it's mounted as low as I can go and changing the trim doesn't seem to do much. Any toon experts able to look at the attached pics and comment if it looks like the motor is mounted too low? From what I found the plate should be in line with the bottom of the transom, which isn't the case here. Anyways, I thought I would ask the community. Thank you for your help in advance.
It's also running a stock prop
Like I said, I am a total newbie when it comes to a pontoon boat, so please bear with me a bit.
