Hi Folks! New guy here -- have lurked a bit in the past but now joining the fray.
I recently excavated an old Avon Rover 2.81 (1997 model) from storage, where it had been rolled up for well over 10 years. I was happy to see that the hypalon tubes inflated and held air! But the inflatable floor is a disaster, leaking air extensively.
I purchased some adhesive and began fixing leaks, but it seems to be a never-ending process. I would fix several, let it cure, pump it up, and several more leaks would open up in other areas. By now I've probably repaired 15-20 places -- all are in the taped seam that connects the top and bottom layers of the airdeck. Whatever adhesive was originally used there, seems to be failing.
I'm thinking of replacing it with a hard floor (wood or aluminum). My plan is to use it as a sailboat tender and I don't really need the roll-up capability of the air deck -- I would keep it assembled most of the time. Has anyone done this? Could I simply cut marine plywood in the same shape as the air deck (coat with epoxy or paint, and put some kind of soft edge around it)?
Alternatively, is it possible to have someone replace the entire taped seam? Or can I get a new air deck for this old dinghy?
Thanks!
Tom
Thanks!
Tom
