G
Guest
Guest
Hi all, i decided Inflatable is not the most beneficial way on getting on the water anymore (will be selling my inflatable and shutting down for the season). Things i have learned:
If your going with inflatable try to stay away from the glued seams. Go for thermowelded if your wallet permits.
Air floor will give you a hard time try to go alluminum or wood floor boards.
inflatable keel will give you issues within time. Transom unglueing will also give you issues.
if you are putting together and breaking apart every outing then travel as light as possible.
Your boat is only as good as your motor. Don't buy what you can't carry. If you have to get less power but more weight friendly GO FOR IT!
If you have the opportunity to trailer, do not buy an inflatable.
FINAL COMMENTS: If you want an inflatable buy a RIB or a folding Rib.
