G
Guest
Guest
i noticed that my keel cannot hold air for a week straight. I am now trailering my boat and have a wooden floor. Is there a foam style keel i can install in its place? If you really think about it, you can replace the inflatable keel with anything that imitates it. i would also assume if shape is not exactly the same you damage the bottom material and the areas its glued to the tubes
