Chopperbill
- Mar 26, 2014
- 389
You can't buy one of those Proud Smokers new here anyway. They should all be rated for four stoke motors.
Alanfox55
I think that the real issue is
The stress of 4 stroke engines as opposed to 2 stroke engines and
Long shaft outboards as opposed to Short shaft outboards.
I believe that all boats should be rated for outboard transom weight as opposed to HP.
To clarify, it's not a physical issue, it's all about performance issue. Will depend entirely if you like boating at idle, fast speed, slow, fast plane, doing tight turns, doing extreme boating. All wooden, alum floorboards flexes when encountering rough waters specially the ones having white caps, doesn't matter how air topped you have that Sib inflated to.
Plastic hollow floorboards flexes worst of all. Although SE has made some mods to strenghthen their foorboards, has done nothing to strenghthen their bow floorboard. If you inflate keel too much, add UV punishment on the medium run will end cracking floorboard in middle. The previous posted cracked floor pics corresponds to SE 420 current production model, has reinforced alum panels unde deck, 4 alum side joiners.
It's not the same using a SE for short time periods, week end summer uses as opossed to daily recreational mundane & extreme uses. Floorboards on Sibs acccounts for at least 50% of its water performance, the other 50% relys on tubes and keel.
With respect to videos, no one shows the real plastic floorboard condition while Sib is on plane, Video says nothing. Having tested a SE 420 with a Yam 25 HP can say that plastic deck flexed hell of a lot more compared to same 420 alum panel deck due to being light and hollow, worst on choppy seas. SE has sacrificed portability,light weight floor, ease of assembly as opposed to deck rigidity which is a must have for best overall water condition such as open waters, non sheltered bays, creeks, etc. uses.
A big flaw seen while watching a SE 420 assembly. Why use a 4 piece, 2 extreme long, 2 extreme short side joiners when a 1 piece long side joiner per side would have been ideal, assures better deck rigidity.
Alan, the only way you can conclude about your 420 being a good or bad water performer would be to test any same size alum floor sib against yours or even racing against one to note the huge water performnce difference between both.
If you need a Sib to walk Miss Daisy on a summer sunny day a SE is what you need. If not in your plans, buy a Saturm, Quicksilver, Mercury Sib, are way better...
Happy Boating
