Saturn says 8.7 psi recommended 10 psi max. Everything that sits on the floor in back looks like it's in an earthquake! Anyone you know have any failures using higher air pressure? I was going to stick the seat frame back in without the seat and post as it was not noticeable then. Rather leave it out. Can get aluminum floor for $300 but if I put any more money in this thing I'm going to be riding solo in the boat and every where else. LOL JUST READ THIS ON THE SATURN SITE
It is not necessary to have an air pressure
gauge to inflate Saturn boats. The boat tubes are equipped with
Safety valves that will prevent over-inflation. In general,
when you feel that boat tubes/floor are hard to the touch, and
it becomes difficult to pump any more air in, that means
that the boat is ready.
However, if you are using a high-pressure electric
air pump, please use below guidelines to avoid boat
over-inflation and consequential damage.
Then they show the air pressure chart.
