gotmehooked
- Feb 25, 2014
- 50
I've read different suggestions for gluing on accessories to inflatables, leave the boat inflated, deflate it, not sure which is best. Looked at a lot of videos to. Last night I glued on my scotty rod holder pad to my boat using the one tube of glue saturn sent me. I sanded the boat where the pad was to go with 180 grit sandpaper to remove the sheen, and did the same to the underside of the pad. I used a 1 inch brush and cut the bristles short to make it stiff. Some of the bristles came off during the application process. I wiped down each surface 3 times with MEK and 5 minutes between, then applied 3 coats of the glue to each surface with 5 minutes in between. I hope it sticks as I don't think I had enough glue and should have waited to order more. So, my question is, do you guys inflate or deflate the boat for hard based accessories and which glue and type of brushes have you found work the best. Any other tips would be useful for future jobs. Thanks.
