Re: air bubble under the floor and cavitation on the prop
Test sib again on flat calm no wind waters and inflate both keels to minimum 0.8 bar or 12 psi and tubes to min 3.0 psi or 0.2 bar. Check if water performance bettered compared to previous defleted run. What's the bar/psi factory recommended working pressure for that V deep keel ? Bear in mind that as soon you place that sib on water, worst if being cold, pumped pressure will drop accordingly, if you have a hand gauge check, probably will need to top 1-2 psi more to compensate pressure loss once on water to maintain 12 psi.
All flat air decks, V deep keels seems not to hold high pressure which were inflated to for long time periods, are prone to experience environmental pressure loss quite fast, much worst throughout the boating day. Tohatsu horses are prone to experiment back transom issues if not properly transom seated, tail design issues. Probably will need a engine/transom match optimization for prop thrust maximization...
Happy Boating
