Re: Trailer for inflatable
Interesting idea regarding whether or not one should have the tubes or the floor bearing the weight. I considered this very carefully as I roll down dirt roads with my trailer and sib. I don't see how I would want any abrasion on my tubes. I went with bunks that are positioned under the floor and inside of the speed tubes my Futura has. The rear of the bunks extends under the transom and the transom is directly supported. I also have two small pads or short bunks up forward to keep the boat from hobby horsing up and down on nasty roads. Yes, I have had some wear on the contact point where the front floor joint rests on those pads. I have also had a slight bit of wear on the transom edge fabric. I would much rather patch the flooring than the tubes! I haven't needed to do anything yet and it has been years since I bought the boat. Just my take on that ( I do have a strong aluminum floor on my Zodiac).If you are leaving the outboard mounted you need the transom to be supported directly.
I do have one unique accessory on my trailer. This large swivel caster unbolts and installs upfront right after the tongue. Great for beach launching where I roll the trailer free from the vehicle. You don't want to damage the tongue pulling out. A long tow strap makes loading the boat in very shallow estuaries possible. Be sure to tie the strap before hand (unless you like to free dive for your trailer in the channel).
The picture shows a reinforcement I added to my trailer to keep it together 500 miles down in Baja. The two uprights are the supports for my front short bunks.
Sure the transom gets stressed by the outboard. A transom saver doesn't take all the load off, but sure does reduce the dynamic loading when you bounce along. I'm not pulling my Nissan 50 with remote controls to travel. If your boat can't handle a little road bounce how is it going to stay together at sea?
Inflatables on trailers are great for towing. Definitely opens up a lot of places. Unfortunately the road is now paved most of the way to this prime fishing spot!
