I'm looking for an inflatable with a power source to use as an alternative to a ~13' swiftwater raft for rivers with intermittant shallow sections.
In most areas, these rivers are deep enough that an outboard works fine, but then has sections that are 1-1.5 feet deep and maybe the most basic type 1 rapids. The area is often used by tubers and kayakers.
While normally much calmer, there was an instance where 6 people paddling upstream on the raft was only able to keep their station against the current
Instead of the swiftwater raft, I was looking at the Saturn / aleko / bris type inflatables with aluminum floor and transom to mount a small outboard.
It doesn't have to be fast, but being able to make at least walking-pace headway (3-4 mph) against a moderate current (faster than you'd want to simply hop out and walk it across) in the 1-1.5' sections is what I am curious about, with 2 or 3 people onboard.
Is there an inflatable / motor combo out there that could fit the bill? Could I simply lower transom wheels into the water so they'd hit the bottom before the prop does?
Regards
Regards
