Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Anchor solution
  • Anchor solution
    I was looking for an easy solution for an anchor attachment point on my Marineer 4 when I found the CamJam at Walmart. They have a plastic version and an aluminum version, I bought both. I will say no way would I trust the plastic version for anchoring but the aluminum one has been fantastic. My first time using it I still tied off the rope with a fair amount of slack between the tie off point (tied to my seat pedestal) and I was in some pretty rough water and there was no slipping in the CamJam so my next outing I did not bother tying off I just relied on the CamJam (much calmer waters though).
    If you go with this option keep in mind the load must be on the back side of the CamJam, if it is on the front side it will not hold.
    i wouldnt use a snap clip on your anchor. thats a good way for the anchor to be lost. just a little slack, the clip slips to where the latch is in the anchor eye and then with a quick tug its unclipped
    if you really want a link at the anchor, get a threaded link. http://www.iboats.com/Boat-Parts-Acc...n%20link&s=sol
    also, your camjam will come undone on you and you will loose the rope.
    best way is to learn to tie knots. eye splice on anchor end and a bowline to the boat.
    http://www.animatedknots.com/indexboating.php
    1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - http://forums.iboats.com/forum/owner...988-rogue-2420
    Past Boats
    1970 Wooster Hellion - Merc 9.8
    2002 SeaRay 190BR - 5.0 - A1G2 - "Cheasheads in Paradise"
    1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
    What’s behind you doesn’t matter.Enzo Ferrari
