Hi
a New fault was revealed (escuse my english if not using exact phrases):
rubber that is surrounding the tubes from their inner side and is glued on the stern is loose! seems that no much adhesives were used originally!
that continues up to the upper edge of the stern wood plate where there it has another rounded layer of pvc that is partially loose but i cannot manage to take the whole thing off due to strong glue there, and above the rounded patch there is another trialngular patch that also is partially free but efforts done by hand with no success taking it off (hope pictures explain better that words).
found in marine shop this glue (p40 is its industrial name) where it has a cleaner and a 2 part glue.
currently i am facing three major dilemmas:
1-should i take of all patches above the rubber band to be able to regule it totally or should i do the parts that i can peel of? if i have to take the whole patches of then should i use heat gun? would hair heater would be enough? by the way, with cleaner it did not help much taking more than muscles did.
2- should i use some clamps to get the rubber bands stick strongly?
3-is this material (p 40 in the picture) would be good for the rubber or it is only to the pvc in your opinion?
by the way, went through all poss here and movies on the net but did not find similar exact case..
would appreciate help here
many thanks
sameh
many thanks
sameh
