BillyBoating
- May 13, 2013
- 67
I was given a Bombard Ax2 with a number of holes in it. In the past I've had great luck using HH-66 to repair PVC, and it seems to be working fine on the holes.
However, I also noticed that the tubes are separating from the rubber transom supports (the rubber parts into which the wooden transom is screwed).
Any suggestions as to what I can use to glue this? HH-66 is awesome on PVC-to-PVC, but I don't know if it will work on PVC-to-rubber.
Thanks
Thanks
