Lake Mead houseboat. Tow boat behind? Length of rope?
DonTomio
Going to Lake mead end of the month. Wanting to tow my boat behind houseboat. Any suggestions on how long of rope I should use?
Thanks for any input.
12vMan
Re: Lake Mead houseboat. Tow boat behind? Length of rope?
You can use 50' safely. Just slow the houseboat down slowly & gradually with someone in the back to relay any problem if the boat is coming in too fast.
The key is slowing the houseboat down s-l-o-w-l-y so your boat doesn't have 'ramming speed'.:D
tdrudd87
Yep, just make sure your boat is riding in a good spot in the wake, not on a wave. Also, make SUPER sure your steering is locked down. Probably also be good to make a Y harness for your boat so you know it is being towed by a true center point.
Terry
tashasdaddy
the length of the line depends on water and wind conditions. you will have to adjust so that the tow rides correctly, in conditions.
BigB9000
I don't really think going slow in the house boat will be a problem...
shrew
Remember to tow with floating line.
12vMan
True, going slow won't be a problem in a houseboat, but the point I was trying to get across was slowing the houseboat down abruptly with the boat in tow too close could cause a collision.
For that reason, it's also a good idea to untie the boat in tow before you beach your houseboat.
Some of the twin screws they rent at Calville move along quite well.:)
fishrdan
We towed with a 100' anchor line last time and it worked well, boat tracked well and didn't get close when we stopped. This wasn't a floating line, but it worked....
One thing to be aware of, the marina's won't let you (at least the 2 I've been to) tow your boat out of the marina. You have to get out of the marina/no wake zone with houseboat under their own power, then once you hit open water you can tow.
jaxnjil
i haven't ever towed like your talking about but have seen as many boats rafted to the side of the house boat and moved, on powell and mead, as well ones towed.
just a though to consider don
DonTomio
Last time I did a 40' but seemed a little close. Tracked great behind HB and know problem when stopping. I think it takes longer for Houseboat to stop anyway. My boat never road up on it. I was thinking about making a Y with a 60' off that to keep it center in HB wake?
Thanks for all the input.
SangerTom
What do you mean by a "Y"? That's two ropes coming from the sides tied to one that goes to the HB or vice versa?
PGFISHER
A "Yis a rope tied to both sides of your stern and a rope in the center to the boat you're towing. This allows you to tow from the centerline of the towing boat, and tends to keep the boat being towed in its wake. If you've ever towed from one side of your stern you'll know what I mean. It causes the towing boat to handle pretty weird, and the towed boat is hard to manage.
