This post may sound like I'm being a bit picky but I just want to get things right.
I am putting on new transom trim for when I get a new outboard. I'm going to use a stainless steel angle that I will buy online. The trim that was original that cracked was 1/16" thick X 1.25" sides and was plastic or hard vinyl.
I found 2 possible items online:
1.) 1" sides at 1/16" thick
or
2.) 1.25" sides at 1/8" thick
How important is the thickness of the trim? I am worried that if I used the 1/8" thick then the new motor will be off by 1/16" from all of the mounting bolt holes.
I definitely DO NOT want to mess that up!
I am thinking to be safe I should use the 1/16" thick but I want the 1.25" sides.
Is mounting bolt height often an issue when repowering, regardless of the trim thickness? I know that if you stick with the same brand motor the bolt holes will usually be identical but height on transom seems like a different story as the mounting bracket thickness would have to be the same.
Any thoughts?
or
Any thoughts?
