I have a 1970 Mirrocraft Titan 15 with a 1970 Merc 500 50HP.
Sometimes I just loose power when going. This isn't an engine issue, engine runs great. Seems to be like, um, the best way to describe it would be to say I'm running out of water around the prop. The RPM's come up and its like I'm sucking or pushing air and than it hooks up again finally but sometimes I loose a lot of power when this happens.
I checked the prop, doesn't seem to be spun.
If the lake it REALLY calm it doesn't happen so much but if there is any chop sometimes I struggle to get going or pull a tuber.
Also if I try to turn while going full speed it pretty much shuts down my movement. The motor doesn't shut down but the boat almost looses all power and just slows right down.
The motor is already drilled for a SE Sports 300 hydrofoil although I do not have one. The previous owner had one but kept it for another boat.
I know a lot of people hate these things but could this help my described issues?
I did try moving the fuel tanks and my cooler up front, under the bow and it does help a little bit.
I know I had a few hundred pounds of wet foam under the deck last year. I started to pull it up last year but discovered that the foam if the structural support, the boat has no stringers. I did not want the boat to be down all season so I stopped and I planned to just pull the new deck up this year and pull ALL the foam, put the deck back in and then cut some holes to pump in foam and go have it re-foamed. Haven't gotten around to that yet though. I did pull the desk over the winter though and let it all dry out. I checked it this year and took some core samples down inside the foam and it seems to be mostly dry now. The only water that has gotten in the boat this year has been what dripped off tubers or fish so unless I've got a leak I don't know about, its should be lighter this year. Still plan to pull the foam and re-spray though.
Like I said it pulls fine on a calm day sucks when there is a little chop.
Thoughts? Questions? Replies?
