SkeeterSkip
- Jul 19, 2015
- 2
I have a 93 Skeeter with a Merc 175 i just purchased, anyhow it needs some work and some TLC and i have a couple of questions to ask.
1. I need to replace the steering cables (2), this is a rotary design, i already have removed the shafts out of the steering tubes and i need to remove them out of the helm rotary device, I have found the pin to remove and the button to depress, i also guess i need to turn the wheel to remove both cables.
The question i have to ask is about the reinstallation of the cables, do I need to feed both cables at the same time of is there a was to do it one at a time?
My 2nd question is this boat needs new batteries, from what i understand is that one battery is for the trolling and the other two is for the outboard motor(I am new to boat ownership), do the batterys have to be the same, I was thinking of getting one battery (trolling motor) the gel type and do I need to get twin batteries for the other two.
Thanks,
Thanks,
