2007rinkercaptiva
- Jul 2, 2015
- 3
Hello everyone, first post here, I have a 1997 chaparral 2130 inboard 350/5.7 Liter. This boat has been sitting most of it's life. It has 204 hrs on the engine and the risers have been changed out once for preventive maintenance. Here's the problem. The trim will go all the way down but when I use the up handle button it only go approx 1/2 up and stops. I replaced both solenoids. Now here's the weird part. I can take the blue and green wires from the trim and switch them. Once I do this I use the down button on the handle and the trim will go all the way up. If I use the up button it will go again on about 1/2 down. I switch them back to normal and the trim goes all the way down but again only 1/2 up. I have a manual but I'm not good with electrical issues, at least thats what I think it is. Thanks,
