Stuck neutral button Mercruiser 3.0
Hey All.
A typical newby question.
Been searching through the forms looking for tips / pictures of how to remove throttle control / neutral button on a 2001 Maxum 1800 SR with a Mercruiser 3.0 Alpha 1. The throttle is not branded as a mercury unit it's got maxum written on it.
I'm guessing the issue is in the throttle lever not the linkage on the engine ?
Engine will not go into gear.
Can't seem to find a diagram or picture of how to remove the button and check the button assembly.
All help appreciated.
Mike -
GA_Boater
Welcome aboard, Mike
Since it's not a Merc control, can you post a photo after reaching 3 posts? It may be a Mercury control with the Maxum name on it.
No Title
Sorry for the delay - had some issues trying to upload these pictures.
Any advice would be appreciated - also if this is the wrong location I can post it in the right location !
Cheers,
Mike
roffey
For what ever its worth that is the same control I have for my Stingray so it must be a mercury control. There is a gear select in the out drive, I wonder if someone changed the impeller and put the outdrive back on incorrectly? Might be easier to check the out drive than disable the safety feature. I can see it now, boat is idling and someone hits the throttle and all head to the stern, in a hurry.
Thanks roffey, whatever happened has happened since I put it in the water or was working correctly until just the other day, no prop work.......
roffey
K, I've spent my vast knowledge, LOL, and I thought I had it. I am sure some more helpful than I will be along shortly.
Removed throttle control - sealed unto with no markings and three Philips screws on the back. I can shift into gear manually at the engine. Nothing else working.
Update - took control unit apart and discovered the neutral button spring was compressed and needed lubrication, and it's all good now.
Case closed.
shrew
Brunswick owns Maxum and Mercury/Mercruiser (AS well as Bayliner, Searay.......). That is a Quicksilver 3000, which is also made by Brunswick. Essentially that is a Mercruiser with a Maxum label on it.
