Ok. Time to fix up old sea ray instead of buying a newer boat (darn)
Going to go through the engine to make sure I don't have to worry about anything. As well as doing a couple performance bolt on upgrades.
First question, I am reading about manifold and risers should be replaced often it seems. My question is, does this apply to a closed cooling system? It's early 90s 5.7 mercruiser. I'd rather not spend the money if I don't have to, or even clean it up and keep using it if I can. But if need be I'll replace what I have to.
Second question. Which bra,d of manifolds and risers to get and what to avoid? And where is the least expensive place to get the parts?
Thanks in advance.
Thanks in advance.
