I have a 1976 Glastron T166 with a 76 Mercury 850. When I put it in reverse it makes a clunking noise and the motor wants to raise up out of the water. Even though I have power trim. With the boat trailered and boat off if I put the boat in neutral the prop spins fine both ways. If I put in forward gear it spins forward but when I put in reverse it doesn't spin in reverse. I checked oil in lower unit and not really any metal flakes only like glitter. Not sure how to fix issue or what is going on. Thanks for your help
