I need some feedback from the community ? boat owners and mechanics if possible.
1995 Sea Ray 230OV 7.4l
Fresh water only, no corrosion/rust/oxidization, excellent mechanical and cosmetic condition
Here's my situation:
Last summer I bought this Sea Ray from a dealer. It was a one-owner lake boat and had been fully serviced by the dealer prior to my buying it. I used it a few times on the lake here in VA. It ran like new.
In November I took it to a reputable marina for a full winterization (flush, oil change, outdrive service, fogging). I trailered the boat to the marina and left it for the winterization. The mechanic took my info. and confirmed that since I have a place on the lake, I didn?t need to store it at the marina for the winter. The mechanic gave me a call when it was done. I went to the marina, picked up the boat, trailered it back to my lake house and parked it, lowered the out drive and covered it for winter storage.
This spring when I pulled the cover and did a preliminary check before putting the boat in the water, I saw that the bilge/engine bay was full of rainwater. The engine was submerged up to the floor level. The water level came to just below the alternator. There was some water that had gotten into the crankcase, probably through the dipstick tube at the block.
I immediately checked the drain plug and saw that it was in place. It had not been removed by the mechanic.
I called him and told him the situation. He offered to take the boat back and look into the situation.
Last week I called him and he said that he?d confirmed that some water had gotten into the engine. He?d fully flushed the system and changed the oil and filter. He tested the engine and said that everything was fine. He acknowledged that the plug should have been pulled as part of winterization and said that he?d eat the cost of the oil/filter change. Even though he tested the starter and confirmed it to be working, he expressed concern about the condition of starter, as it had been submerged for at least a month over the winter.
I picked up the boat on Friday, towed it back to my lake house, put a full charge on my battery, and the starter wouldn?t kick. Nothing. No click of the solenoid?.nothing.
So here?s my question in a nutshell:
What degree of responsibility does my mechanic have for leaving the plug in?
Is removing the plug by the mechanic as part of winterization a reasonable expectation?
Should I be the one who has to take the hit of new starter replacement, or is it reasonable to expect him to replace the starter at his cost?
..or to what degree should he be responsible for the starter failure? Labor only?
I?m not sure of the degree of labor, but since this is a big block, it might require the engine to be pulled?
My family came down to the lake for a weekend of boating over Memorial Day weekend. I?m not thrilled with what happened, but I?m trying to keep my emotion out of this. I like this mechanic. Mistakes happen, and from what I can tell up to this point, he?s taken responsibility for leaving the plug in.
Everyone I've spoken to seems to have an opinion on this, but I want to be fair, unbiased and unemotional.
I want to discuss this with him and do what?s fair for him and for me.
Opinions please.
Thanks.
Opinions please.
Thanks.
