wakerider09
- Aug 31, 2013
- 54
I have a 2003 Doral 250se.... I believe the marine unit is a Marine Air System - I believe the manufacturer is out of business at this time, but I keep getting an HPF fault when I use the unit on shore power. Moreover, pump works fine, it runs for approximately 3-4 seconds and then suddenly shuts off and the control adjustment shows an HPF fault??
has anyone seen this before, or know what it means? Des anyone know the type of Freon this unit would use? Not sure if there are different kinds of marine Freon or if they are standard?
Thanks.
Thanks.
