We all know the only way to get the right prop is by putting it in the water to test it. When I went to Iboats and purchased the Solas HP i was asked for only yr. motor and HP(this is not complete because you need boat length and weight). My old prop was a 25" pitch 13.75 dia. They said the 14 X 25 Solas would work and it wouldn't get the boat on plane. I went back to them and they said it should be a 19" pitch so either way I would get the wrong prop. Now they won't refund my money because the prop touched the water. I received I'm sorry and that is sad, now you know and I hope it steers you to the right place to shop.
