Johnboatcaptainron
- Mar 13, 2015
- 5
Just bought this 81 grumman aluminum boat with trailer. Gave 650 for it. No leaks. I hope it will make a good stable fishing platform for my son and I. It has. 5'4" beam and is rated for a 25hp motor and 825lbs people and gear. Haven't been able to find out much about this style boat or even what style it is. It looks a lot like a tri-hull to me. It has hard chimes and the bottom has a slight v at the rear. When I put it in the water to test for leak I could sit on the gunwale comfortably and I'm nearly 300lbs. I'm working on a 63 10hp Johnson and 57 7.5 evinrude(with pressure tank) that I picked up together for 250. Both had good compression and lower units. My question is do you think the 10hp will get this boat on plane? I thought if I could get both motor running good, I could trade or sell them both for a 20 or 25 if the 10 was not enough to get on plane. Really don't care how fast it goes, and I know some people are going to say, run the max hp rating, but I would like to keep both motors and use the 7.5 on a small flat bottom jon for the small rivers and creeks. Thanks for any input or info on this style boat.
