I just picked up an 89 bass boat and the fittings (hose barb fittings) to the pumps for the livewell are below the water line. Obviously if I replace these with more plastic barb fittings and these or the hoses break, I'll be in trouble.
Where can I find a plug type fitting that will eliminate this?
Also, if I did use similar fittings, almost all hose intakes say for 'ABOVE the water line'. Can I find them for below?
