TBarCYa
- Apr 13, 2005
- 781
The port side exhaust flange was leaking so now that it's out of the water, I started digging into it and found some interesting stuff.
First off, the port side flange is significantly smaller diameter than the starboard side. 3 1/2" on one and 3 1/8" OD on the other. The exhaust pipe is the same side on both and on the port side, it's a 3.5" ID rubber hose that slips over the exhaust pipe and was just clamped to the 3 1/8" flange. That to me seems to be a potential source of the leak.
Here's where it gets ever weirder. The hole in the transom is only 3 1/8" so it seems like the origianl flange size was 3 1/8" but the starboard side was changed to 3 1/2".
So my plan is to try to find a 3 1/2" OD flange for the port side, cut out the transom to the right size and replace the rubber hose. The problem is that everywhere I call tells me that they're either 3" or 4" and that 3 1/2" is an odd size so first question... Is 3.5" an odd size? Am I better off trying to find a 3.5-3.125" adapter and using the flange I have? It would be less work, but I'm pretty sure the exhaust should be the same size on both sides.
