The FWC has developed an online survey for future use in drafting anchoring restrictions for local municipalities. Their goal is to allow cities and local governments the ability to restrict your rights to anchor in certain places. Most notably, in areas that have waterfront homeowners who think they have a right to govern the water behind their homes.
Boaters need to make sure that any restrictions on anchoring are done on a state-wide basis.
The survey and it’s “concepts” are designed to restrict your ability to choose where and for how long you can anchor. Please respond to the survey, even if you don’t live in Florida.
My suggestion is that you mark question #7 as “None - Authority to regulate should remain with the state”
Also, my suggestion is to “strongly disagree” with the “concepts” so that they come up with a state-wide solution to the problems they present.
