Need help.I have a 26 ft StarCraft islander with a 1989 4.3 omc cobra going to do full reno on boat.I have winterized engine my question is .I can not see any drive water drain screws on starboard side .i have seen pics of wear there to be. would it be possible the year is wrong. I'm waiting for maniual to arrive. Can't find any marks on engine tag is not readable for model and year
Thanks
Not sure what you mean by 'drive water drain screws'. Are you saying that you found the
engine block drains on the port side of the engine, but can't find any on the starboard side? Or, are you referring to drains on the
outdrive? And, how about the drains on the manifolds and/or risers? Did you find those?
In any case, you should be posting this in the OMC I/O forum to get the right answer(s). Maybe one of the mods will move this for you.
