powermargin
- Oct 4, 2014
- 3
Hi all, sorry for the stupid question -- but I'm new to the boating world, having just purchased a 2001 Crestliner Fishhawk. My only previous experience with boating was with those little tin rentals, so there's a lot I'm learning about my new boat (which is part of the fun)
Can someone tell me what this device is that's mounted off my transom (not the transducer, the other thing with the long arm)? As far as I can tell, it might be something that tells speed relative to the water, perhaps a pitot? But it seems odd to me that it seems to be flipped up and not down. If I try to push it downwards, it only goes about 45 degrees before there's a hard stop, any further and I feel like it will break.
Also one of those black tubes hanging there is just open-ended and not attached to anything. Is it supposed to attach to that black device? It seems to lead back to the engine, where I would have expected it to lead up to the instrument console.
I'm thinking of buying a new fishfinder, so I'd like to remove this if I don't really need it, to give me more space to mount the new transducer.
Second question -- since I'm not sure how long it's been since the bearing were serviced, I'm going to do this pretty soon. I've read enough about how to replace and repack bearings that I think I can give it a try, but in looking at parts, I see that buying a whole new hub isn't really that much more expensive than the bearing and seal kits. The existing hub seems to work just fine, but it might be worth the extra $ to replace the 13-year-old, been in saltwater, hubs just for the peace of mind. Is there any downside to replacing the whole hub? Alignment, balance issues, etc...?
Third question -- on the instrument console, there's a circle in the middle with no gauge in in. Interestingly, every picture of old Crestlners I've seen also have that spot empty. What was there originally? Perhaps just a Crestliner badge that tends to fall off?
Thanks in advance!
Thanks in advance!
