New to fishing boats. Have a 2002 Crestliner Nova aluminum 17ft boat (like a tracker). It has a live well that I'm not sure how it works. I have a manual and automatic switch on the cockpit. Inside the well there are two tubes one at the top (where the water is pumped in from the outside and one a bout 3/4 up the tank (that goes to a overflow port out the bottom of the transom). My question is what keeps the water from coming back in the boat if I leave the overflow plug open and if I want to add periodic fresh water to keep bait/fish alive how does the overflow work when the hole is "below the waterline"? Is it just simple physics that the water cannot rise above the level of the overflow pipe?
