Only good for a kneed pad. Get a factory manual for what you are working on.
You can boast all you want but it doesn't take much experience to know that the Seloc is not worth the paper it is written on. The Merc manuals expect that you have some mechanical skills so are written a little different but are exact. I have all the Mercruiser manuals in PDF form and didn't pay a dime. You can also get the online versions for free at boatinfo.Whatever your experience it doesn't compare to mine. I had both and I actually preferred the Seloc over the Mercury for several reasons akin to understanding the problem and seeing how to fix it. I got mine electronically right here in a couple of minutes with a subscription to their online manual.
Mark
Everybody has an opinion and an.............well you know!You can boast all you want but it doesn't take much experience to know that the Seloc is not worth the paper it is written on. The Merc manuals expect that you have some mechanical skills so are written a little different but are exact. I have all the Mercruiser manuals in PDF form and didn't pay a dime. You can also get the online versions for free at boatinfo.
^This, +1. As a mediocre DIY wrench, one way to bump up your skills is to learn from as many resources as possible. OM, Seloc, iBoats, retailers websites, asking questions on the dock, etc.You hit on the precise reason I like to have both. Yes, the factory manual has all the correct information, and it's written for the trained mechanic with all the right tools. A Seloc is written for the DIY'er and can walk you through repairs that aren't clearly described in a factory manual. When I owned my Johnson outboard, there was more than one procedure in the OMC manual that left me scratching my head. When I turned to the Seloc the light came on, and it provided an alternative method to using the diagnostic tools I don't own. Add in a factory Parts Manual that shows how everything fits together, and you can tackle almost anything. My .02
The problem comes when the info is wrong and ends up making you ruin what you are working on. Seloc has a lot of wrong info.^This, +1. As a mediocre DIY wrench, one way to bump up your skills is to learn from as many resources as possible. OM, Seloc, iBoats, retailers websites, asking questions on the dock, etc.
