Condor1970
- Jun 9, 2014
- 195
Just curious what method some of you have decided to use to secure and hold down your doghouse. I basically just went with a couple of angle brackets on the floor near the back of it under the back seats, to hold it down in place. Screwed to the floor, and with a stainless bolt through the side, I can unscrew it to remove the doghouse when I need to. Some seem to use big piano hinges, but for some reason, I'm not too keen on the idea. The only issue I can see having, is if something bad happened, and I had to pull the doghouse off quickly. The bolts do require me to reach in behind it, and it takes a minute to get them off.
Any other suggestions?
I wonder if I shouldn't just take the brackets off for good, and let it just sit there by its own weight.
