Asking Price is $18,500. NADA runs from $17,990 (low) to $20,365 (average). Performed a buyer's check- compression ok, 3/8 spark plugs were loose. A few lights to fix, one sprayer head for the pressure water system. Steering cable and Tachometer need replacing. Stainless steel prop has a few dings on it. Outdrive visual inspection ok - bellows intact. All other systems function normally.
I lake tested the boat- we were out for about an hour. The boat runs well- no engine noise, doesn't take on water and appears otherwise solid. I'm guessing about $2,500 to put the boat back in top condition from what I see.
Thoughts?
