Re: Installing captain chairs
Captains' chairs can be difficult to install - the moment generated by the weight of a person at the end of a pedestal causes a lot of force at the mounting bolts.<br /><br />1) They have to be through-bolted through a large backing plate of heavy plywood or metal with large scale quality fasteners. If you can't get to the underside of the deck at that location, forget it.<br /><br />2) Some boat decks are thin to begin with on elcheapo brands, or have become soft over time with water incursion. Regardless of backing plates etc, you can still rip a pedestal chair out if the deck is not solid/sound.<br /><br />An alternative if it can't be mounted properly is to use the kind that come with a storage box below. This gives you a much larger contact area with the deck. And the bending moment is much shorter (and presumably properly addressed by the manufacturer since the pedestal mounts to their own box).
