ruleofthumb
- Oct 9, 2007
- 5
I just purchased a gently used 2003 17' Hurricane deck boat w/90hp Mercury 4-stroke, and am at a loss to explain this problem. At most any speed up on plane, water cascades up, thru and around the motor mount, goes over the transom and into the motor well and will actually fill it up. This causes water to flow into the bilge through the boot at the motor control lines. It's just odd. I've tried different trim settings and that helps somewhat but it doesn't stop the waterfall. The motor (original to boat) appears to always have been mounted as it is now. This boat design has a small inset hull cavity, below the transom and in front of the lower motor leg, where the bilge plug resides. Perhaps it is causing turbulence or? Any thoughts? Thank you.
