I recently purchased a Bayliner 242 Ciera Classic and decided to also purchase a Honda 2000 portable generator as a power accessory. However, when I pluged the shorepower line into the generator my AC inverter monitor showed a red reverse polarity light. The inverter was fine while connected to a regular shorepower outlet but not with the generator. I have heard this is a common problem with small portable units and that if you pigtail the neutral wire to the ground wire it corrects the problem. But...so much for my warrenty??? Any ideas out there to help me?
