Re: How do I best use my trim tabs?
Trim tabs are like flaps on airplane wings - down when you are at slow speeds, up when you are cruising (basics). <br /><br />Manual (helm controlled) tabs like you have allow you to control the attitude of the boat in all directions. Front to back, side to side and corner to corner. <br /><br />Power is not everything - hull shape and design is just a important to performance. Ie a barge will never pull skiers, and a shi boat will never carry 500,000 Lbs. <br /><br />Trim tabs allow you to widen the efficiency window of operation by changing the hull design. <br /><br />It will help you plane easier ( tabs down or deployed), cruise at lower speeds on plane (partially deployed), or control balance by deploying one or the other tabs more than the oposite one ( ie: in quartering seas).<br /><br />Learning to use them may require soome practice, but it is worth the effort.<br /><br />Where I disagree with the other comments is the fuel savings issue. If you trim your boat to its most efficient attitude (under any given conditions or speed) the boat will be more fuel efficient. <br /><br />As far as getting on plane is concerned, there may be a "Best Position" of deployment which will depend on power, and tabs size. The most deployed position may be too severe to allow the best acceleration because they may act too much like breaks. In most cases theis fully deployed angle should not exceed 25 degrees. and if installed correctly, this would not create a breaking effect. The angle of deployment is a benefit for planing as it increases the lift at the stern. Since the boat rotates on an axis stern up means bow down.<br /><br />We do not make helm controlled trim tabs, we make automatic self controlled tabs called Smart Tabs (typically for boats up to 22'). However, there is nothing you can add to a boat that will improve the overall performance and handling than trim tabs. <br /><br />Learn to use yours by practicing. Try not to practice with a boat load of people.
