I have a tracker targa that needs a new(second) automatic bilge pump.It would go beside the replacement manual pump put in by the last owner. Question is in order to keep the pump upright it has to sit on the aluminum hull. Is there a glue to fasten a mounting plate to aluminum that is not affected by water. Has someone solved this problem in the past?
