Walleye Dan
- Apr 28, 2014
- 16
Well, talk about a rookie question....no laughing please. How can I gauge when the drain plug is tight enough. Don't want to strip it yet want it tight.
I too. finger tight, have taken pliers and tighten just a speck more,,, dont need to crank on it. What I would suggest is that you get a second one and keep it inside the boat, just in case you misplace one.. dont want to get to water and release you dont have a plug..[/QUOTE
Thanks. I've seen these plastic hand tightened and wondered if they would get it tight enough. Looks like the answer is yes.
It only need to be tight enough to not leak, and not fall out.
Finger tight, plus another 1/4 turn, is way more than enough.
