sptjet90Reflexx
- May 28, 2011
- 383
2004 Sea Ray 240 Select - 496 Merc / Bravo I
Previous issues with out-drive oil leaking and no water pumping have been repaired at the dealer before sale.
See attached photos!
The right trim plate is missing. According to the sea ray manual it is a 10x12 plate. I called a sea-ray dealer and they said a new one is about 250.00 for the part alone.
Is this trim system automatic? Could I ride the boat without the replacement plate? The closest plate replacement I could locate on ebay was:
Bennett 10 x 12 M120 Sport Tab Trim Plane Assembly TPAM120 | eBay
This one has a different design however it looks like the hinge plate has the same 4 mounting bolts so I was thinking of just installing the plate only?
