Hi all, just took my boat out after a good year of sitting. I have a fiberglass Hull - it's a Lonestar from the late 50's I think 12 or 14 ft.
So I put the boat in the lake and forgot to plug the drain at the back of the boat. I hopped in after just a minute and put a wine cork in to stop the water coming in (successfully). Not much water got into the boat thankfully.
My question is: After I scooped out most of the water, I noticed that there is another drain plug near the transom drain plug. This second drain is not on the transom - but rather faces the port side of the boat but is located just a few inches from the transom drain plug.
Is this some kind of Bilge drain? I noticed that water is coming out of there as well - but only fills to the top of the tub area where the transom drain is located. As I continue scooping this out the little tub area continues to fill with water from this drain but the water only fills to a certain level and then no more. Is this normal or is there excess water in the hull somewhere?
Any advice is always greatly appreciated
