Re: Running AC off Batteries?
Is it possible? Yes... For how long is the question... A 5000 AC will draw around 650 watts, so 54 amps at 12v. Add 20% for inverter loss, so 65 amps. Group 29 deep cycles are usually around 100 amp hours, BUT... that is for a low amp load, 1 amp per hour. Drawing 65 amps constant will give you well under an hour runtime, I'd say more like 30 minutes MAX unless you want to seriously shorten the life of the battery.
On the other hand, if you are wiling to take the hit in weight and set up a proper battery bank, it can be done. 4 or 6 6v-trojan batteries would give you a decent amount of runtime.
(Disclaimer, you need a VERY healthy inverter to start up an AC unit, minimum of 2000 watts if not larger.)
A small 2000+ watt suitcase generator would be a much better choice for intermittent use like this.
