Bought a used boat last fall and the fuel gauge was not working. Took the sending unit out yesterday. The arm is stiff and will not follow the fuel level down. It works fine throughout it's range(on the gauge) but stays at full. The float raises it but it won't fall with the level. Has anyone tried a Wema unit? If they work well I want to try a more reliable unit. They recommend 1" clearance under the sensor but My tank is only 4" deep and their shortest unit is 4" deep. What do you think?
Thanks for any input, John
