I've got a little 16' Bayliner outboard that I'm going to be keeping in a slip this season for the first time. It presently has 3 cleats - one on each side near the stern, and one front/center on the bow - these are somewhat limiting, even just when putting the boat in/out at the ramp, as well as when getting gas, etc, especially when trying to tie lines and hang fenders off of the side cleats (and hanging fenders over the bow side from the grab handles...) The slip will house 2 boats, so I'll need to moor it on one side only (starboard side, FWIW, though clearly I'd like to be able to moor it on either side).
I've purchased 4 lightweight pull-up cleats for hanging fenders (Fish-On Fender Cleats, presumably, I want 2 each side), as well as 2 'real' cleats (Perko 4.5" stud-mount cleats) to add to each side, presumably somewhere around the mid-point (The windshield will force the cleats to be a bit ahead of the mid-point, but this will put them at the widest point of the boat.)
I've tried to attach a diagram from the owner's manual that shows the locations of the current 3 cleats, as well as the general layout of the boat. I'd welcome advice on where to place the two new mooring cleats, as well as the 4 fender cleats. Any additional advice on how/where to attach the lines (there is no piling or tie-off in the middle of the slip, so all lines will be on one side of the boat) would be welcome. This is a freshwater lake, with no tide change, and the marina is reasonably-well protected, though we rarely get huge storms here in far-inland VA anyway. (and if we were forecast to get the dregs of a hurricane or such, I'd likely go pull the little tub out of the water anyway...)
Oh, I'll have a 'semi-custom' cover on it, which currently prevents access to the cleats, so my plan is to cut access holes for the cleats, then sew on velcro-backed covers. I'm hoping that this will also help to secure the cover to some degree, at least on the one side.
Another item of note - we tend to go over the side near the rear seating area with waterskis, so avoiding placing anything on the side from the rear of the windshield to the rear seatbacks would be preferred.
Thanks for any help!
