You should open up your own thread since it is a different question. On my Crownline 202BR the switches are nav lights, bilge, horn, blower on the left. On the right is 4 switches but only one does anything and that is the lights for under the dishboards. The 3 others are accessory switches that are there for later use if needed. Yours may be similar. The Nav Light switch is easy to figure out because it has 3 positions and the others have 2.HI, I have just purchased a 2003 230 CCR, it looks as if the wall should just unscrew, white caps on the screws just pull off. Can you help me with identifying the eight switches on the dash? All the labels have worn off and some switches appear to do nothing, I may have some electrical problems!
Any help appreciated, regards to all.
